What is mean of crash file in rp-bootdisk?
Apr 12th, 2010
We found that the crash file is in the Router-process bootdisk at Cisco 7609 Router.
Generally, when the device generates the crash file, the crash file records in the SP sup-bootdisk.
but in RP bootdisk, What mean of crash file info in C7609 with RSP 720?
In my opinion, when the device generate the crash file at system, the file is copied with duplicate between sp-bootdisk and rp-bootdisk?
or not, what is mean?...
In my guess, when the device switch over boot role from sp to rp, during rp booting occured some problem. so the rp generate the crash file its bootdisk?
the forcus is 'during rp booting'
I would be appreciated in your answer!
thanks
Regard.
