vg 248
Apr 12th, 2010
I have configured the ip address  7 the subnet mask in the VG248.But I am not able to ping to my pc(not able to ping by by itself.)what could be the problem.???can anybody give me the step by step.another question is I have seen some are telling to issue commands for Vg248.How to issue commands because  its console not like router's console , and we can select only menus.??
thx
Ganesh Hariharan Mon, 04/12/2010 - 02:44
thx
If you have given the ip address to the interface configre the ip address to pc with same subnet mask and try ping the pc ip address from vg248.Check the subnet mask and gateway configured in PC and check out the below link on getting started on vg248.
http://www.cisco.com/en/US/docs/voice_ip_comm/vg248/1_2_1/english/configuration/guide/vg248swc.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
WEERAKOO69BA Mon, 04/12/2010 - 03:00
hi I gave 32.93.36.81/24 to Vg248 & 32.93.36.80
/24 to pc,but no use.vg248 not even pi
ng by itself
Ganesh Hariharan Mon, 04/12/2010 - 03:09
ng by itself
Just check the interface of vg248 is up , you should able to ping the self interface of vg248 first then only you can ping the pc from vg248.
Have you configured the network setting as per the link
http://www.cisco.com/en/US/docs/voice_ip_comm/vg248/1_2_1/english/configuration/guide/vg248swc.html#wp1023313
Hope to Help !!
Ganesh.H
