Multicast VPN with C-Anycast on PE supported?
Answered Question
Apr 12th, 2010
Are C-Anycast RPs  supported in a mVPN solution?
We are a  service-provider. We use cisco PEs (MPLS and native PIM-SM/SSM in the core ->  draft rosen)
The PEs (c7609,  SUp720, 12.0 SRD) must play the role of the C-RP (two different PEs for each  mVPN). We want to have
C-RP redundancy  with C-Anycast and MSDP running between those c-RPs.
I couldn't find a statement that C-Anycast with mVPN on PEs is supported or not.
thanks for the help
Correct Answer by Laurent Aubert about 7 years 2 months ago
Hi Harald,
I tested it quickly and it's working. My PE's are running SRC3 and SRE:
AS1-PE2-6509#sh run | beg ip msdp
ip msdp vrf MVPN peer 172.16.3.254
ip msdp vrf MVPN cache-sa-state
ip msdp vrf MVPN originator-id FastEthernet3/2.700
ip pim vrf MVPN rp-address 1.1.1.1 override
AS1-PE2-6509#sh ip msdp vrf MVPN sa-cache
MSDP Source-Active Cache - 1 entries
(40.1.1.1, 224.1.1.1), RP 172.16.3.254, BGP/AS 1, 00:03:03/00:05:15, Peer 172.16.3.254
AS1-PE3#sh ip mroute vrf MVPN
(40.1.1.1, 224.1.1.1), 00:01:56/00:03:23, flags: TA
Incoming interface: Tunnel0, RPF nbr 10.1.1.4
Outgoing interface list:
Ethernet1/0.10, Forward/Sparse, 00:01:56/00:03:20
AS1-PE3#r | in ip msdp
ip msdp vrf MVPN peer 172.16.2.254
ip msdp vrf MVPN originator-id Ethernet1/0.10
Laurent.
Overall Rating: 5 (1 ratings)
Laurent Aubert Thu, 04/15/2010 - 20:21
  • Cisco Employee,
MSDP is VRF aware so it should work.
Did you test it ?
Laurent.
HARALD ZECH Fri, 04/16/2010 - 00:46
Yes, MSDP is VPN-aware and I tested it. It
didn't work. No information was exchanged although
connectivity was ok.
However, the problem is most likely more related to
the way MSDP is treated in a draft-rosen based core.
Correct Answer
Laurent Aubert Fri, 04/16/2010 - 06:31
  • Cisco Employee,
Hi Harald,
Laurent.
HARALD ZECH Wed, 04/21/2010 - 08:14
Hi Laurent
I found the problem. Our control-plane policing (COPP) was blocking MSDP
(and causing other Multicast issues). Your reply confirmed that MSDP is really working and so
I could focus to other possible causes.
Thanks for your help !
Harald
Related Content
