04-12-2010 03:47 AM - edited 03-15-2019 10:12 PM
In CDR Analysis and Reporting what is the difference between CAR database and CDR database.
Solved! Go to Solution.
04-12-2010 06:42 AM
CDR is plain Call Detail Records which can be used by other systems.
CAR is when the info has already been processed and is the source of info for the Cisco CAR reports.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
04-12-2010 06:42 AM
java
04-12-2010 10:12 AM
Ok. That means CDR is raw format i.e the one that we export from call manager which is in txt format. The cdr is further refined to form CAR which is used for generating different reports in pdf or excel.
04-12-2010 10:16 AM
Yes, that's correct. CDR DB info is what the plain files that CUCM generates after each call contain. It can be used by 3rd party programs which then process the info for enhanced reporting.
CAR is the CDR info processed to be used with the CAR tool.
java
