04-12-2010 03:48 AM - edited 03-15-2019 10:12 PM
I got couple of dial-peer in my configuration, donno which is used for incomming and outgoing.
During an active call is it possible to get the dial-peer information.
Sip phone vendor wants to enable rtp encryption on CME, any help on it
cheers
TOM
Solved! Go to Solution.
04-12-2010 05:20 AM
dial-peer voice 11 voip is your incoming dial-peer and the rest are outgoing..
Hope this helps....
04-12-2010 04:20 AM
Can you post your dial-peer config here...
04-12-2010 04:57 AM
Here it is....
voice-class codec 1
voice-class sip dtmf-relay force rtp-nte
session protocol sipv2
session target sip-server
incoming called-number .%
dtmf-relay rtp-nte
no vad
dial-peer voice 12 voip
destination-pattern 9……….
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 13 voip
destination-pattern 9011T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 104 voip
destination-pattern 9[6]......
voice-class codec 1
session target ipv4:192.168.1.100
incoming called-number ....
dtmf-relay sip-notifydial-peer voice 100 voip
description dial peer digital toward CUE
no voice-class sip g729 annexb-all
codec g711ulaw
dial-peer voice 101 voip
destination-pattern 9[11]......
voice-class codec 1
dial-peer voice 102 voip
destination-pattern 10..
voice-class codec 1
dial-peer voice 133 voip
destination-pattern 9[00]..........
voice-class codec 1
dial-peer voice 135 voip
destination-pattern 95..........
codec g711ulaw
04-12-2010 05:20 AM
Hope this helps....
04-12-2010 05:16 AM
Impossible with third-party phones.
