Reconfiguring an aggregated link protocol from PAgP to LACP
Apr 12th, 2010
I tried to convert an existing PAgP aggregated link to LACP but having problems bringing up the bundle. I did the following:
1. Config T
2. int range gi3/46 - 47
3.   no channel-group 99
4. exit
5. no int po99
6. int rang gi3/46 - 47
7.   channel-group 99 mode active
8.   channel-protocol lacp
9.   no shutdown
10. exit
11.int po99
12.  switchport
13.  switchport mode access
14.  no ip address
15.  swi acc vlan 10
16.  sp auto
17.  band 2000000
18   no shut
13.  end
The Portchannel 99 was re-created but it's  status is down/down and all member ports are showing as unbundled/single. Also, I noticed the description field of the new Po99 is the same as the old po99 instead of being blank - meaning that it was copied from the old configuration.
What is the recommended way to reconfigure the Portchannel if I want to use the same portchannel number ?
And strangely, the HP server that the ports are connected to, with SLB teaming configured ports, show the teamed port up ? What does this mean in terms of the operation of this link ? That is, would the host be LACP load-balancing on the two ports whilst the switch operates them in redundancy ?
Thanks for your response.
Sankung
shailesh.h Thu, 04/15/2010 - 10:45
  • Bronze, 100 points or more
Can you please actual output of interfaces , status of etherchannel and port channel..
sawosankung Thu, 04/22/2010 - 10:33
Dear support,
One more question relating to EtherChannel.
We have a 2x1gbps EtherChannel link built between an Access and Core switch in our Data center using two ports in a WS-X6548-GE-TX linecard module. However, I read in one Cisco document that only one port per module should be used in an EtherChannel because of the ASIC configuration in this type of module which limits the channel to 1gbps.
Please can you tell me whether this is still the case with C6509 running IOS 12.x. Otherwise, what is the recommended selection of ports for EtherChannel using the WS-X6548-GE-TX ethernet module.
Thank you very much.
Sankung
