I HAVE A PROBLEM WITH 2 ASA 5505
Apr 12th, 2010
Hello i have a problem, when i connect through ASA 5505 site to site (site 2 "DC2" to site 1 "DC1"), outlook 2007 (in DC2 ) can not run.
and  I want both  routers know all users of both sites. ie routers must be authenticated users of the two  wholes areas.
thanks.
MEDALIMACH5 Tue, 04/13/2010 - 15:19
please  have you any sollution ?
s.v.p je veux une reponse ..
Kelvin Willacey Wed, 04/14/2010 - 20:43
  • Bronze, 100 points or more
Not quite sure what you are trying to do. Can DC1 and DC2 communicate over the VPN ie can you ping or log on to the servers from the remote end. If so then your problem may lie with the servers of the clients.
Some more explanation may help.
shailesh.h Thu, 04/15/2010 - 09:27
  1. Check your tunnel setup
  2. Check your interesting traffic
  3. Check ping between two sites (ISP to ISP) or IPSec port.
Once your basic steps completed then check why desired communication not happening
With regards,
Shailesh
