BGP Behaviour
ccnak1ing
This is more of a cosmetic issue than an actual fault
I have 3 devices A, B & C.
A & B are ebgp neighbors, C & B are also ebgp nei
A sends 3 prefixes to B while C sends 1620 to B
B sends all 1620 + 3 routes to both neighbors A & C
I know BGP will forward learnt prefixes to peers and if peers see their AS number in the AS path they ignore the prefix.
My question: is there any way to stop B from sending back to A & C the prefixes it has already learnt from them? this will make troubleshooting much easier I guess.
2 Accepted Solutions
milan.kulik wrote:
Hi Jon,
ad "An EBGP peer does not advertise the networks it learns from one peer back to that same peer."
I know BGP works this way.
But I tried to find this statement in several documents and books and failed :-(
Is it specified in some BGP RFC?
Milan
Milan
Good point. I don't know is the short answer, i was just going off practical experience. Would seem a bit stupid if they did keep readvertising each others networks back and forth
Perhaps a lab is called for !
Jon
Hello CCnak1ing,
Neighbor        V  AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down   State/PfxRcd
100.100.100.1   4 100   115    112        914    0     0   1w0d                      3
300.300.300.3   4 300   103     116        914    0    0   1w4d                     1620
RTB#sh  ip bgp vp vrf Global nei 300.300.300.3 received-routes | i  Total
Total number of prefixes  1620
RTB#sh ip bgp  vp vrf Global nei 300.300.300.3 advertised-routes | i Total
Total  number of prefixes 1623
RTB#sh ip bgp vp vrf Global nei  100.100.100.1 received-routes | i Total
Total number of  prefixes 3
RTB#sh  ip bgp vp vrf Global nei 100.100.100.1 advertised-routes | i  Total
this doesn't mean that the 3 additional prefixes are coming from neighbor 100.100.100.1 you have a redistribute connected in BGP Address family ipv4 vrf Global so I would expect those three routes are connected
address-family ipv4 vrf Global
neighbor  100.100.100.1 remote-as 100
post sh ip route vrf Global connected
if you have 3 prefixes you should be fine
Hope to help
Giuseppe
14 Replies 14
Jon Marshall
Are A & C in the same AS ?
Jon
No, A is a WAN distribution device while B is my edge device peering with C which is my ISP edge device.
Then why should B advertise A's routes back to A ? and the same question for C ?
Jon
That's my question and how to stop this from happening as i only want to see in B's advertise routes to C routes learnt from A and vice versa
Sorry, i shoud have been more specific. An EBGP peer does not advertise the networks it learns from one peer back to that same peer.
So if A advertises routes to B then B doesn't advertise them back to A unless you have somehow setup a redistribution loop somewhere.
B should advertise A's routes to C and C's routes to A but not A+C's routes to A & C.
How have you got this configured.
Jon
Hi Jon,
Milan
milan.kulik wrote:
Hi Jon,
Milan
Milan
Jon
Hello Milan,
not in a direct way but:
One of the most important path attributes is the AS-PATH. AS
   reachability information traverses the Internet, this information is
   augmented by the list of autonomous systems that have been traversed
   thus far, forming the AS-PATH.  The AS-PATH allows straightforward
   suppression of the looping of routing information. In addition, the
   AS-PATH serves as a powerful and versatile mechanism for policy-based
   routing.
RFC 1774
Hope to help
Giuseppe
Hi Giuseppe,
there was another thread here recently discussing "why does a BGP router send updates containing the neighbors AS within the AS_PATH?".
https://supportforums.cisco.com/message/3042419#3042419
And the conclusion was it's each BGP router responsibility to drop such updates.
I've found in RFC 1771:
"A BGP speaker must never advertise an address of a peer to that peer as a NEXT_HOP, for a route that the speaker is originating. A BGP speaker must never install a route with itself as the next hop."
I'd say that's what a had been asking for, but the "for a route that the speaker is originating" is confusing me again (English is not my native language).
Routes received from the neighbor are not originated by the speaker, so it seems they could be advertised back...:-(
@Jon:
This is something on my "when I have some time" list since the first time I read about the dynamic update-group Cisco feature.
I always thought "If an update group means all the members are receiving identical updates, how does the BGP router filter out the routes received from a particular router not to send them back?"
Is it possible the Output Policy Engine on a Cisco router is making this check - not mentioned explicitely anywhere?
The only document which mentioned this rule I found is the famous "Internet Routing Architectures - 2nd Edition" book.
I found there on page 294:
"Note in Example 11-35 that 192.68.10.0/24 is actually learned via two different paths,
whereas 192.68.11.0/24 is learned via a single path. This might seem misleading, but actually
routing is doing the right thing. In this situation, RTF has decided that the best path to reach
192.68.11.0/24 is via RTA (check RTF's BGP table in
Example 11-34). This is why RTF will
not advertise network 192.68.11.0/24 back to RTA and why RTA will have a single entry for
192.68.11.0/24."
BR,
Milan
I'm running mpls and have vrfs/vpns config'd on A and B, my ISP manages C. C is in an AS300 that connects all my other sites together so site-to-site comms goes thru C.
A-->B-->C-->D-->E
Config on A (AS100)
router bgp 100
address-family ipv4 vrf Global_A
neighbor 200.200.200.2 remote-as 200
neighbor 200.200.200.2 activate
neighbor 200.200.200.2 soft-reconfiguration inbound
Config on B (AS200)
router bgp 200
neighbor 100.100.100.1 activate
neighbor 100.100.100.1 soft-reconfiguration inbound
neighbor 300.300.300.3 remote-as 300
neighbor 300.300.300.3 activate
neighbor 300.300.300.3 soft-reconfiguration inbound
RTB#sh ip bgp vp vrf Global sum
Hello CCnak1ing,
Hope to help
Giuseppe
that's correct for 100.100.100.1 but still doesn't explain why it's readvertising 1623 routes to 300.300.300.3.  I'm looking at implementing the following filter list:
neig 300.300.300.3 filter-list 1 out
ip as-path access-list 1 deny ^3_
ip as-path access-list 1 permit ^1_
ip as-path access-list 1 permit ^$
As i'm redistributing connected I don't think I need to advertise the /30 networks
Hello Ccnak1ing,
clearly 300.300.300.3 is not an IPv4 address but just a placeholder.
locally generated BGP routes have empty AS path as seen on local node:
this line allows locally injected routes so you see 1623 routes sent to "300.300.300.3"
the neighbor will see an AS path = ASN of local node
Hope to help
Giuseppe
ccnak1ing
Thanks to all who contributed to answering this post, I found all very useful.  I set up a lab scenario for this and got the same result of routes being readvertised to Router B however B dropped these routes as it's as was in the as path.  When I implemented the filter list on A and C only the connected and locally generated routes were sent.
