Upgrading WLC 4400
Apr 12th, 2010
How is the correct steps for the upgrade of the WLC4400 from a version 4.1 to 4.2 version?
I backup the configuration running in the version 4.1.
I download, and put the file of the Software 4.2 in the TFTP directory.
I start the transfer from the TFTP to WLC.
The copy was succesfull.
I restart the WLC and Save the config.
But, the WLC lost the configuration (running the version 4.2), I connect to the console port and this showed the Wizard to start the initial configuration :S
What is the correct steps to upgrade WLC.
Rob Huffman Mon, 04/12/2010 - 07:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Ricardo,
This is a good doc with Step by Step info
Wireless LAN Controller (WLC) Software Upgrade
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00805f381f.shtml
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
