Problem with wireless Accesspoint 1252AG-E-K9
Apr 12th, 2010
I have a wlan network with 4404 controller,1252 access points and WCS. My acess points are powered through POE. Now when i checked the alarms in my WCS i saw an alarm saying " AP X associated with controller X is drawing low power". My switches are catalyst 3750G switches and they support maximum of 15.4 W inline power. Is there any way to solve this issue other than connecting a power injector?. And please advise me what are the problems that i will face if the access points are running on low power?.
Rob Huffman Mon, 04/12/2010 - 07:45
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Shabeeb,
You'll probably find this thread very helpful
It has some great answers from some of my NetPro faves!
https://supportforums.cisco.com/message/1269333#1269333
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
Leo Laohoo Mon, 04/12/2010 - 17:47
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
What is the firmware of your WLC?  Firmware 6.X allows the 1250, with both radios operational, to be powered up with 15.4W.  The "cost" is lower MCS rates.
shabeebkp Wed, 04/14/2010 - 08:50
My WLC version is 6.0 . The access points are up and running. But the typical error comes again n again in the WCS. If the power is low will there be any effect in signal strength??... Pls reply....
Leo Laohoo Wed, 04/14/2010 - 15:35
  • Hall of Fame,
    2017 LAN, Wireless
Yes.  Some of your higher MCS rates are disabled.  Basically, you can get both radios functional but the "footprint" of the radio signals is lower.
