ASA droped package
Apr 12th, 2010
we are running an ASA firewallsystem and getting
Teardown TCP connection 56410XXX for outside:XX.XX.XX.XX/1521 to  inside_demo003:XX.XX.XX.XX/1199 duration 0:00:00 bytes 3334 Flow closed by  inspection
Anyone can tell me, the
"closed by inspection" message
is sent by the ASA for what kind of firewall discrepancy ?
I checked the cisco docs on here, but I just found some shallow info on this.
Maybe there is a larger style error table somewhere that I did not find yet.
It also would be great, if someone could guide me a little bit more in the direction for what valid reasons a packet can be dropped in the above case. (packet inspection) Maybe there is a matrix for it.
Thx in advance
Federico Coto F... Mon, 04/12/2010 - 07:49
This is a TCP connection being closed by the inspection on the ASA.
The ASA by default has a default inspection policy that you can check on your configuration and its applied globally.
sh run class-map
sh run policy-map
sh run service-policy
Is this connection for a particular TCP protocol?
Panos Kampanakis Mon, 04/12/2010 - 11:23
TCP port 1521 is protocol sqlnet. Probably sqlnet inspection is closing that connection.
You would need to check the "sh policy-map" as suggested.
If you have sqlnet problem check the ASA version, earlier 8.0 version had a couple of defects with sqlnet inspection.
I hope it helps.
cisco.xenpak1 Tue, 04/13/2010 - 04:03
how to find the
        ^^^^ number behind a version ?
When I go to the software download page of cisco i just get offered
8.0.4 ED without any of the .43 number shown.
How to find out, what release cisco lets you download under 8.0.4 ED ???
Kureli Sankar Tue, 04/13/2010 - 04:11
8.0.4 interim is at asa804-48-k8.bin.
You need to open a TAC case and have the engineer publish the code for you.
