Questions Regarding NAT on PIX/ASA
Answered Question
Apr 12th, 2010
Hello Everyone,
I've done a bit of reading on the topic of NAT on the PIX/ASA but still have a few questions that I'm looking for clarification on.
Based on the diagram attached, I'm thinking there are 3 ways to get this working with NAT. There is no need on the PIX/ASA in the diagram to allow the users to access the Internet. The Internet here is used only as a method to establish a LAN-to-LAN IPSec tunnel.
Method 1: no nat-control command. This should exempt ALL traffic from NAT, right?
Method 2: Static command
static (Inside,DMZ) 10.132.1.0 10.132.1.0 netmask 255.255.255.0 0 0
static (Inside,DMZ) 10.1.1.0 10.1.1.0 netmask 255.255.240.0 0 0
static (Inside,DMZ) 10.2.2.0 10.2.2.0 netmask 255.255.240.0 0 0
static (Inside,DMZ) 10.3.3.0 10.3.3.0 netmask 255.255.240.0 0 0
static (DMZ,Inside) 10.132.65.0 10.132.65.0 netmask 255.255.255.0 0 0
static (Outside,DMZ) 10.16.1.0 10.16.1.0 255.255.255.0
Method 3: NAT/Global command
nat (Inside) 0 10.132.1.0 255.255.255.0
nat (Inside) 0 10.1.1.0 255.255.255.0
nat (Inside) 0 10.2.2.0 255.255.255.0
nat (Inside) 0 10.3.3.0 255.255.255.0
nat (DMZ) 0 10.132.65.0 255.255.255.0
nat (Outside) 0 10.16.1.0 255.255.255.0
or possibly this could work as well?
nat (Inside) 0 0.0.0.0 0.0.0.0
nat (DMZ) 0 0.0.0.0 0.0.0.0
nat (Outside) 0 0.0.0.0 0.0.0.0
- Do I also need "global" statements like these in order for the "nat" commands to work properly or is that just needed if I was sending traffic to the Internet so the clients could browse websites?
global (Outside) 0 interface
global (DMZ) 0 interface
global (Inside) 0 interface
- For traffic going from an interface with higher security level to a lower one, traffic should be allowed I believe.
- If going from a lower security level to a higher one, I know I need an ACL to permit the traffic.
- Do I also need a static NAT translation?
- Would the "nat (DMZ) 0 10.132.65.0 255.255.255.0" command work to exempt NAT on traffic from the lower security level interface to a higher one or would only the static NAT translation be looked at for this?
- If both "static" and "nat" commands, are the "static" commands looked at first before the "nat" commands?
Thanks for the help!
-Pete
Correct Answer by Federico Coto F... about 7 years 2 months ago
For traffic to flow from lower-security to higher-security interface you need:
STATIC NAT and ACL
If you have NAT-CONTROL disabled, you only need ACL
For traffic to flow from higher-security to lower-security interface you need:
NAT
If you have NAT-CONTROL disabled, you don't need any other commands.
If there's an existing ACL, it should allow the traffic.
NAT order of operation:
1. NAT 0 access-list
2. STATIC NAT/PAT
3. Policy NAT
4. Dynamic NAT/PAT
Federico.
Overall Rating: 5 (1 ratings)
Correct Answer
Federico Coto F... Mon, 04/12/2010 - 08:27
  • Green, 3000 points or more
STATIC NAT and ACL
NAT
2. STATIC NAT/PAT
3. Policy NAT
4. Dynamic NAT/PAT
Federico.
priedman1 Mon, 04/12/2010 - 11:00
Thanks for the help Frederico,
This is very helpful.
-Pete
