Apr 12th, 2010
Does anyone know why I can't  choose YRYBY through Show & Share as an input option on the  encoder.  I can create a VOD/Live Event and pull directly from the  Streaming Server, but if I want to do a true Live Event with a good  quality camera and want to use anything other than composite or S-Video,  I cannot do that through the DME settings on Show & Share.  Is this  some sort of technical limitation.
Thanks in advance
Tomas De Leon Thu, 04/29/2010 - 08:07
Maybe, I am misunderstanding your question.
The Live Event Module using encoders are specifically for Cisco Digital Media Encoders.  The DME inputs
for video are S-Video & Composite.  That is why you only see these two choices.  The Camera would be
directly connected to the DME-Encoders on either one of these choices.
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
Tomas De Leon Thu, 04/29/2010 - 08:21
Forgot to add the SDI Interface also which is available on the DME-2000 & DME-2200
