AtoM configuration not working on 7206
Apr 12th, 2010
       I have been trying for several days and have downloaded different IOS but to no luck. Can't get this AtoM to work on my Cisco 7206. I am just wondering if someone can tell me which IOS should work Following is my configuration output.
The following works on Cisco 7204 VXR. But not on my Cisco 7206. I am desperate...Please assist.
R-8(config)#int fastEthernet 1/0.123
R-8(config-subif)#encapsulation dot1Q 123
R-8(config)#pseudowire-class ETH
R-8(config-pw-class)#encapsulation ?
  l2tpv3  Use L2TPv3 encapsulation
  mpls    Use MPLS encapsulation
R-8(config-pw-class)#encapsulation mpls
R-8(config-pw-class)#interworking ip
R-8(config-subif)#xconnect 150 ?
  encapsulation  Data encapsulation method
  pw-class       Pseudowire-class to use for encapsulation and protocol
R-8(config-subif)#xconnect 150 pw
R-8(config-subif)#xconnect 150 pw-class ETH  <--- It doesn't take this command and gives me following error.
MPLS encap is not supported on this circuit   <-- This is the Error I get.
Cisco IOS Software, 7200 Software (C7200-P-M), Version 12.2(25)S15, RELEASE SOFTWARE (fc1)
Technical Support:
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 07-Dec-07 18:26 by tinhuang
ROM: System Bootstrap, Version 11.1(13)CA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-BOOT-M), Version 12.0(19)S, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
R-8 uptime is 6 minutes
System image file is "disk0:c7200-p-mz.122-25.S15.bin"
Cisco 7206 (NPE200) processor (revision B) with 114688K/16384K bytes of memory.
Processor board ID 13253628
R5000 CPU at 200Mhz, Implementation 35, Rev 2.1, 512KB L2 Cache
6 slot midplane, Version 1.3
Last reset from power-on
Number of Fast PAs = 3
Number of Fast+Medium PAs = 4
Total number of PA bandwidth points consumed = 630
Please refer to the following document "Cisco 7200 Series Port
Adaptor Hardware Configuration Guidelines" on CCO <>,
for c7200 bandwidth points oversubscription/usage guidelines.
4 Ethernet interfaces
1 FastEthernet interface
4 Serial interfaces
1 ATM interface
8 Channelized T1/PRI ports
1 Packet over SONET interface
125K bytes of NVRAM.
4096K bytes of
00:06:47: %SYS-5-CONFIG_I: Configured from console by console packet SRAM memory.
62720K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
4096K bytes of Flash internal SIMM (Sector size 256K).
vmiller Mon, 04/12/2010 - 11:26
If i Read the feature navigator right that release isn't listed as supporting MPLS.
It shows 12.2(24) then jumps to 12.2(26)
shassan655 Mon, 04/12/2010 - 11:32
I am just wondering whic IOS...should i use. I have downloaded several and tried them..but no luck. ...Any idea ??
Mounir.Mohamed_2 Mon, 04/12/2010 - 11:53
The chassies is irreleevant, it's come down to the NPE version and  the IOS code ran on, however full Point-to-point L2VPN internetworing options supported in 12.2SB and ongoing --> 12.2SRx, but your NPE might be your bottleneck.
shassan655 Mon, 04/12/2010 - 12:23
Hello Mounir,
             This is my Lab environment. I can try c7200-p-mz.122-31.SB17.bin on my Cisco 7206 and see if the command will work on not. I think in other IOS feature which I downloaded earlier on Cisco 7206 also had MPLS on AToM but no luck to get it to work. ...I will go home and download this on the router and see what happens.
Giuseppe Larosa Mon, 04/12/2010 - 13:44
Hello Shassan655,
take in account that
releases with a C2700p in the name are for NPE G1 or NPE G2 not for older NPE like NPE 200
sh ver | inc NPE
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
sh ver | inc image
System image file is "disk2:c7200p-advsecurityk9-mz.124-20.T.bin"
you cannot run a release for NPE-G1 or G2 over an NPE 200
From feature navigator to support EoMPLS on C7200
ADVANCED IP SERVICESc7200-advipservicesk9-mz.122-33.SRE1.bin51264
if you have 512 MB of RAM and 64 MB of flash but you have  128 MB of RAM and 16 MB of flash so no match and probably you cannot increase RAM on an NPE-200.
for NPE-G2:
ADVANCED IP SERVICESc7200p-advipservicesk9-mz.122-33.SRE1.bin1024256
I see you have a C7200-p that is a different matter then what I have reported above
Hope to help
vmiller Mon, 04/12/2010 - 13:52
You must never sleep. I missed the p in my troll thru feature navigator. good call.
Forza Roma.
