Supervisor 720 Health Check/SNMP/Syslog
Answered Question
Apr 12th, 2010
I have multiple 6500 Catalyst switches with redundant Supervisor 720's. Periodically a redundant sup will fail. I need a syslog message or SNMP trap sent to our network management software. What are some options to configure this? Even better would be a way to remotely actively monitor the standby sup state.
Keith
Correct Answer by Joe Clarke about 7 years 1 month ago
If you want to monitor module status, take a look at the moduleStatus and moduleStandbyStatus objects from the CISCO-STACK-MIB.  In a healthy switch, the active sup will have a moduleStatus of ok(2) and a moduleStandbyStatus of active(2).  The standby sup will have a moduleStatus of ok(2), and a moduleStadbyStatus of standby(3).
You can also enable module traps:
snmp-server enable traps module
And that will send moduleUp and moduleDown traps which indicate that a module's moduleStatus has transitioned from or to the ok(2) state.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 04/13/2010 - 23:03
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
