Can i use Nbar for Cisco 7609 routers to monitor the Layer 4 and above protocols?
Apr 12th, 2010
hi
I want to monitor the Layer 4 and above protocols on router 7609.
Can i use NBAR for it?
If yes, then how to use it?
If no, then any other alternative way to do it?
regards
abhishek nagar
+447829933033
Giuseppe Larosa Mon, 04/12/2010 - 10:37
  • Hall of Fame,
    Founding Member
Hello Abhishek,
if your C7609 has a sup720 installed you cannot use NBAR on it.
I would suggest you to consider netflow instead.
Hope to help
Giuseppe
