CiscoWorks log export
Apr 12th, 2010
So my organization got a logging solution called Logrhythm a while back. the operator of this server is asking if the Ciscoworks LMS syslogs can be exported to it. I'm not much of a Ciscoworks guy yet but can they be exported to another logging solution?
Also...has anyone ever heard of Logrhythm? So far I haven't met anyone. If so what's you're take on it?
Giuseppe Larosa Mon, 04/12/2010 - 13:59
  • Hall of Fame,
    Founding Member
Hello Applesmash,
I would suggest you  to post this question under network management forum, where you can find better answers
Hope to help
Giuseppe
Related Content
