DMP 4400 rs232 connection with samsung 40" lcd
Answered Question
Apr 12th, 2010
Hi, i´m testing the dmp with an lcd from samsung. I´m using the rs-232 port just to turn on and  off the monitor.
I have same questions:
1- wich rs-232 cable should be used straight? null-modem? The documents i checked do not mention that.
2- I was testing it with my pc first instead of the dmp, 9.6k 8n1 no flow control, with no sucess.
3- Hexa commands for Samsung lcd, there is a table?
Thanks for any lead.
Carlos
Correct Answer by dmarchywka about 7 years 2 months ago
I believe it is a null modem cable.  That has worked for me.  I have attached a PDF that I found that describes how to create RS232 hex commands for Samsung displays.  I have tried a few from this list and they worked for me.
Overall Rating: 5 (1 ratings)
Correct Answer
dmarchywka Mon, 04/26/2010 - 10:07
carlos_canepa_2 Mon, 04/26/2010 - 10:52
I also Used an RS232-cross cable and work for me.
db9 female                                       db9 female
5 (GND) -----------------------------------------5 (GND)
  3 (TX) ------------------------------------------2 (RX)
  2 (RX) ------------------------------------------3 (TX)
  8 (CTS) -----------------------------------------7 (RTS)
  7 (RTS) -----------------------------------------8 (CTS)
  6 (DSR) -----------------------------------------4 (DTR)
  4 (DTR)------------------------------------------6 (DSR)
Thanks for the Samsung Document.
Carlos
