32-bit application for 7925 USB or just https?
Apr 12th, 2010
  • Bronze, 100 points or more
I’m setting up a bunch of 7925Gs to CallManager 7.1 and reading the 7925G deployment guide.  Been awhile since I did some 7920/21s.
For some reason I thought there was a new 32-bit application for use with USB for configuring these (other than Avalanche SE).  I was hoping to export the config and import via USB quickly as opposed to a https web page import/export.
Instead it appears the laptop USB driver enables https to the 7925G (192.168.1.100). Which I guess is cool of your wireless profile isn’t setup.
Tell me if I’m on the wrong track…
I'm also noticing the SCCP 1.3(3) to 1.3(4) firmware update is taking about 60 minutes per phone via WLAN.
