NAC OOB Virtual Gateway and Dynamic VLAN assignments
Apr 12th, 2010
Hello all,
I need to implement VLANs mobility both in wired and in wireless network, according to the group that the user is part of Active Directory. how I do it?
Juliano Lopes
Faisal Sehbai Mon, 04/12/2010 - 22:06
  • Gold, 750 points or more
Juliano,
You can't do that with Wireless OOB. With Wired, here's how to configure Role-Based VLANs, assuming you're on the latest version of CCA:
http://tinyurl.com/y3njz4b
HTH,
Faisal
juliano232 Tue, 04/13/2010 - 10:09
Faisal,
Thanks for your reply, because the NAC does not support mobility of wireless network with VLANs based on Active Directory groups, this means I'll have to use the ACS to do that? And for the wired network I can use NAC for Role-Based VLANs according to the Active Directory group is assigned to vlan user? This is the best scenario to deploy mobility for both wireless and wired network?
Juliano
juliano232 Tue, 04/13/2010 - 15:49
Faisal,
The NAC does not dynamic VLAN assignment based group that the user is part of the AD to the wireless network, I can integrate the ACS, WLC and NAC to meet this request of my client?
Juliano
