UCCX 8 questions
Answered Question
Apr 12th, 2010
     I just installed UCCX 8 Premium with HA and have a question.  Is there a set of default scripts that come with the install?  I can't seem to find them anywhere.
Correct Answer by Aaron Harrison about 6 years 10 months ago
Also note that the built-in/system scripts are pretty much the same thing as the templates available in the CRS Editor when you click new.
E.g. icd.aef = Simple_Queueing template
Rmon.aef = Remote_Monitoring template
If you really want to access them, assign one to an application and note the script name when you configure it (e.g. SSCRIPT[rmon.aef], including the double 'S'). Go into CRS Editor, then do a reactive debug, and enter the script name e.g. SSCRIPT[rmon.aef]
Call it, and your system script will debug. You can then save it out after you hit the 'stop debug' icon.
Aaron
Please rate helpful posts...
Overall Rating: 4 (3 ratings)
shikamarunara Tue, 04/13/2010 - 08:09
Yeah, I looked in the obvious places and couldn't find default scripts.  I'm hoping to be wrong about this, they come in handy (and are also a big help to script newcomers.)  Maybe I haven't looked hard enough on the server.
BTW, CRS8 looks excellent so far.  Glad they went to Linux.  Installation and configuration were a breeze for anyone who's done it before, loving it so far.
Correct Answer
Aaron Harrison Tue, 04/13/2010 - 08:54
Aaron
shikamarunara Tue, 04/13/2010 - 09:05
I don't see an option for templates when I click new, but I noticed that when I went to create a new script from scratch that it showed an wfavvid_801 folder in my Program Files folder.  So, with this platform apparently the sample scripts are stored on the CRS Editor user's machine, not on the server.  Cool.
Anthony Holloway Tue, 08/31/2010 - 09:16
You have to use File > New, not the New icon in the toolbar, in order to see the new script template window wizard thing.
