Is there a command line/console login for the SLM2048?
Apr 12th, 2010
It seems all 5 of our SLM-2048s have issues and need to be rebooted every 2 weeks to keep things running ok (note we have other cisco equip and some dlink, none of which have issues). After reviewing many posts here and elsewhere it appears I'm up the creek as to getting them fixed since it's a flaw.
Instead of having to login to the web UI to reboot them I'd like to setup a batch file to reboot them on scheduled interval. Is there any other means of logging into these switches aside from the web UI? Or is my only choice a remote power switch?
Thanks.
