EIGRP bandwidth question....
Answered Question
Apr 12th, 2010
This is a question that never got answered on the cisco learning network fourm that I am curious about....I never could find the answer.
If you change the default EIGRP bandwidth from 50% to something else with the ip bandwidth-percent EIGRP AS %% command, where can you look to see this change reflected?
Thank you,
Jimmy
Correct Answer by hstoddart about 6 years 9 months ago
Correct Answer by Tharak Abraham about 6 years 9 months ago
Jimmy,
You can indirectly check this by having a close analysis on how EIGRP paces its packet.
The "sh ip eigrp interface" should give you a column indicating the pacing time in millisecs.
Each time a data packet is queued,  EIGRP determines how long to wait before sending the packet based on the formula
(8 * 100 * packet size in bytes) / (bandwidth in kbps * bandwidth           percentage)
This does have an effect on the protocols behaviour on the links !
Hope that helped !
Correct Answer by Jon Marshall about 6 years 9 months ago
Jimmy
Do you mean other than doing a "sh run" because if you modify the eigrp bandwidth on an interface it will be reflected in the running config.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Tue, 04/13/2010 - 01:26
Jimmy
Jon
Correct Answer
Tharak Abraham Tue, 04/13/2010 - 05:05
Jimmy,
Hope that helped !
jimmysands73_2 Tue, 04/13/2010 - 17:22
Thank to all that replied.  I was really just interested in this question because it never got answered on the Cisco Learning Network fourm.
I think the correct answer is the only place we will see this change is the startup/running config.
