ANI is not being displayed for some cases
astanislaus
Level 2
Level 2
Voice Gateway: Cisco 3845 router.
Software Version: 12.4(12b)      c3845-advipservicesk9-mz.124-12b.bin
Problem Details:
Customer is complaining that they cannot see one particular ANI in the Agent
desktop even though they can see it in the IP Phone. The ANI cannot be seen even in the
syslog traces (taken from the VG). SingTel (telco provider) adds 8810161 as an ANI if the
customer blocks ANI.
For calls coming from AUSTRALIA the ANI that SingTel (carrier) gives is 8810161 and
from New Zealand it is 8810164 and from Singapore the ANI is 8810165. 8810164 and 8810165 is
displayed correctly in the syslog traces, IP phones and the agent desktops but only
8810161 is not displayed as expected.
From the debug we can see the diffrence between the
call with the ANI 8810161 and 8810164 / 5 is that 8810161 has the feild "PLAN" asn
"UNKNOWN" and "TYPE" feild as "UNKNOWN" whereas 8810165 & 4 has  "PLAN" asn "ISDN" and
"TYPE" feild as "SUBSCRIBER (LOCAL)".
Log snippet:
Mar 22 12:07:21.467: ISDN Se0/3/0:15 Q931: RX <- SETUP pd = 8  callref = 0x3E08
Sending Complete
Bearer Capability i = 0x9090A3
  Standard = CCITT
  Transfer Capability = 3.1kHz Audio
  Transfer Mode = Circuit
  Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
  Exclusive, Channel 1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Display i = '8810165'
Calling Party Number i = 0x41A3, N/A
  Plan:ISDN, Typeubscriber(local)
Called Party Number i = 0xC1, '6040165'
Comparing the result with 8810161, the difference is:
Display i = '8810161'
Calling Party Number i = 0x00A3, N/A
  Plan:Unknown, Type:Unknown
ANy suggestions on troubleshooting this further ?????
5 Replies 5
Aaron Harrison
Either you have copied that debug output across in a very odd way, or the service provider is incorrectly signaling the information in.
On the second trace for '8810161' you have two 'calling' number elements, but no 'called' number elements. If this is a verbatim copy of the debug, then raise a call with your service provider and send them that debug as evidence of what is being signaled incorrectly.
Aaron
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
The way I cut and pasted the debug output may have confused you:
Here it is to clarify:
When calling from Australia (the problem situation) we get in debug the following:
When calling from Singapore (the working situation) we get in debug the following:
Dpn't worry about the rest of the debug information, such as calling number, etc.
I want to know why in one case (failing case) I get
and in the other case (working case)  I get
In last reply I should have said:
Don't worry about the rest of the debug information, such as called number, etc.
Generally once you have received the call, CallManager and the other products are pretty indifferent to these number/plan types. The only common usage I'm aware of (in the inbound direction) is to insert prefixes to national/international numbers so they can be dialed back easily.
If you are going to chop about your debugs before posting them you may as well not bother. Post the whole SETUP message.
If you don't like what you are receiving in the SETUP message, you have two options:
1) Raise it with your service provider if you think it's incorrect
2) If it's just not quite what you want, you can translate the number plan/type and numbers either on the gateway (using H.323, most flexible) or on CCM (generally limited to basic changes to the called/calling numbers only, much less flexible).
Aaron
Thanks Aaron.
I chopped teh debug output just to show the difference between working and failing situations.
Thanks again.
I will try your suggestion on VG.
