1861 switchport port-security command
Apr 12th, 2010
Dear All,
I just need to confirm that either 1861 CME routers support switchport port-security .... commands are available???
If yes then on which IOS and if not then what is the alternate to fix the port security on the 8-port ethernet card?
thanks,
Leo Laohoo Mon, 04/12/2010 - 22:57
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
3-port ethernet card???   I've never heard of one.  Can you provide the model number of this card?
Leo Laohoo Mon, 04/12/2010 - 23:07
  • Hall of Fame,
    2017 LAN, Wireless
8-port switch on an 1800 ISR G1?  You mean the NME-XD-48ES-2S-P?
IF so, then it won't work because this is supported starting from the 2800 router.
Cisco EtherSwitch Service Modules for Cisco Integrated Services Routers
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d15f.html
Shaikh Aman Uddin Mon, 04/12/2010 - 23:13
then please tell me how I can configure switchport security on 1861 ethernet port???
Leo Laohoo Tue, 04/13/2010 - 15:19
  • Hall of Fame,
    2017 LAN, Wireless
If indeed you are using the module, it's not the question of you can or can't configure.  It's a question of whether or not the module is even supported on the 1800 router.
Leo Laohoo Tue, 04/13/2010 - 21:48
  • Hall of Fame,
    2017 LAN, Wireless
What is the complete model number of the module?
Leo Laohoo Tue, 04/13/2010 - 23:08
  • Hall of Fame,
    2017 LAN, Wireless
Oh nuts.  I forgot about this model.
Port security should be supported.  Can you post your config and what you are trying to do?
Shaikh Aman Uddin Tue, 04/13/2010 - 23:30
Dear Friend,
I am trying to put the command in the interface mode...
switchport port-security .....
but this command is not available in this router.... do I need to configure it some other way or need ot upgarde the IOS... If the IOS then which IOS???
Aman
Leo Laohoo Wed, 04/14/2010 - 02:19
  • Hall of Fame,
    2017 LAN, Wireless
Are you entering the command on the LAN ports or the WAN ports?
Shaikh Aman Uddin Wed, 04/14/2010 - 03:23
Friend,
I am configuring switchport security on the LAN interfaces, IP phones are terminating on these ports directly......
shailesh.h Wed, 04/14/2010 - 06:10
  • Bronze, 100 points or more
Would you please share the output of sh ver
Shailesh
wilson_1234_2 Wed, 04/14/2010 - 14:05
Here is how it is configured,
It will not shut down the port, but prevents traffic other than what is specified from passing:
mac-address-table secure 0007.0002.0006 FastEthernet0/1/1 vlan 7
