QOS on ATM Interface
Apr 13th, 2010
In one of my remote office, we have a 1841 device (c1841-advipservicesk9-mz.124-19.bin) with a WIC-1ADSL=that is used for Internet browsing and access to our private network through an ipsec gre tunnel.
As the internet browsing is consuming a lot of bandwith, i would like to prioritize some packets to the internal network when they transit through this device.
Though, i'm unable to find the good configuration.
I used the following link as a reference http://www.cisco.com/en/US/tech/tk39/tk824/technologies_tech_note09186a00800d76b5.shtml but when I tried to apply the service-policy on my atm subinterface, it gave me the following error "CBWFQ : Hierarchy not supported for ATM VCs"
Here is a part of my config
class-map match-any critical_app
match access-group 100
policy-map bandwith
class critical_app
  bandwidth percent 50
class class-default
  bandwidth percent 25
policy-map parent
class class-default
  service-policy bandwith
interface FastEthernet0/1
ip address 10.10.1.1 255.255.255.0
  ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface ATM0/0/0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
dsl operating-mode auto
hold-queue 224 in
interface ATM0/0/0.1 point-to-point
pvc 0 0/50
  vbr-nrt 480 480 1
!!!!!!! I tried to apply the service policy here!!!!!!!!!!!!
  pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
ip virtual-reassembly max-reassemblies 64
encapsulation ppp
dialer pool 1
dialer-group 10
ppp authentication chap callin
ppp chap hostname user
ppp chap password 0 password
crypto map WAN
ip nat inside source list 10 interface Dialer1 overload
access-list 100 permit tcp any any eq 99
How can i simply set up a low latency queue for the packets concerned by the ACL 100 ?
Giuseppe Larosa Tue, 04/13/2010 - 02:07
Hello Mathieu,
you can apply the CBWFQ scheduler directly to the PVC because you have defined the ATM traffic parameters with vbr-nrt command (otherwise it would not be accepted).
You don't need the external shaper, well you have no shaper in parent policy because the ATM traffic parameters act also as a shaper.
apply directly bandwidth scheduler, I would suggest a different name
Also taking in account that GRE and IPSec copy on external headers the internal headers if needed you can provide an LLQ to IP precedence 5 for VOIP RTP bearer channels, some bandwidth to other packets in the VPN connection and you don't need to assign resources to class class-default it uses what is left free.
class voip
match ip precedence 5
class vpn
match ip address    100
policy myscheduler
class voip
priority percent 10
class vpn
class class-default
random-detect
int atm0/0/0.1
pvc 0 0/50
service-policy out myscheduler
of you can apply it directly on atm subinterface or under ATM main interface (I had to do so on a C877)
Hope to help
Giuseppe
mathieuploton Tue, 04/13/2010 - 07:26
Hello giuslar,
Here is what I get :
interface ATM0/0/0
no ip address
no ip mroute-cache
hold-queue 224 in
pvc 0 0/50
  vbr-nrt 480 480 1
  service-policy output myscheduler
Do you think it's ok like that ?
Because when I do a show policy interface, it's just empty, nothing appears !
And if i try to apply it direclty on the atm interface, it says : CBWFQ : Not supported on this interface
Giuseppe Larosa Tue, 04/13/2010 - 07:35
Hello Mathieu,
try to use a 12.4T image, in my case on C877 I had to move to 12.4T because I saw no matches on policy-map int, with no config change with just change of IOS the problem was fixed
Hope to help
Giuseppe
jhalterman805 Wed, 11/03/2010 - 14:02
I had the same result when I tried to apply the service policy to this interface and I am running 12.4(11)T3.
interface ATM3/0
description Primary link to SJC
no ip address
ip flow ingress
atm clock INTERNAL
atm scrambling cell-payload
interface ATM3/0.32 point-to-point
description Data PVC to SJC
bandwidth 42000
ip address 10.0.0.5 255.255.255.252
no ip redirects
ip flow ingress
no ip mroute-cache
no snmp trap link-status
pvc 1/32
  oam-pvc manage
  oam retry 3 10 1
  encapsulation aal5snap
interface ATM3/0.33 point-to-point
description Voice PVC to SJC
bandwidth 3000
ip address 10.0.0.9 255.255.255.252
ip flow ingress
pvc 1/33
  vbr-rt 3000 2000 32
  oam-pvc manage
  oam retry 3 10 1
Did you resolve this problem?
