E3 Controller Problem
Apr 13th, 2010
Sir,Following is the output of my E3 controller.
What is the meaning of E3 9/1/0 is up.How to avoid   11 P-bit Err Secs, 11 P-bit Severely Err Secs,
      11 Severely Err Framing Secs, 71 Unavailable Secs,
      0 Line Errored Secs, 11 C-bit Errored Secs, 11 C-bit Severely  Errored Secs.Whether it is due to E3 card Problem or Transmission problem.
E3 9/1/0 is up.
  CE3 H/W Version : 4.2.1, CE3 ROM Version : 1.1, CE3 F/W Version : 1.2.1
  Applique type is Channelized E3
  Total available channels 128, used 16
  No alarms detected. Line Code is HDB3, Clock Source is Internal.
  0 PA software resets.  0 E1 framer resets. 149 E1 throttles.
  Data in current interval (94 seconds elapsed):
     0 Line Code Violations, 0 P-bit Coding Violation
     0 C-bit Coding Violation
     0 P-bit Err Secs, 0 P-bit Severely Err Secs
     0 Severely Err Framing Secs, 0 Unavailable Secs
     0 Line Errored Secs, 0 C-bit Errored Secs, 0 C-bit Severely Errored Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 0 P-bit Coding Violation,
     0 C-bit Coding Violation,
Thanks and Regards,
Senthil
paolo bevilacqua Tue, 04/13/2010 - 04:23
  • Hall of Fame,
    Founding Member
These errors in itself are not significant.
However, you shold èprobably use clock line, not internal.
Send complete "show interface".
