String variable of Unicode characters problem
Apr 13th, 2010
Hi all
I define a variable named "vRemoteParty" ... with String type
in order to store the return value of "7748"
I got the following result via the UCCX debugger ...
Result: U"\u3737\u3834"
suppose it is result: 7748 ...
So. how can I convert this unicode character in UCCX script??
I tried the String.valueOf() but seems not working
Anyone could help
Sam
samhopealpha Wed, 04/14/2010 - 20:40
I found that the problem only existed while connected to MySQL database
The STRING returns correctly if querying with Microsoft SQL.
Does it mean the UCCX does not support MySQL??
or there is any setting should be changed in MySQL or UCCX
Sam
Related Content
