Time is not correct on Cisco IP Phones.
Apr 13th, 2010
I have CUCM 7 (Publisher and Subscriber) i set the timezone on both the Servers to Asia\Kuwait
and i also set the Data/Time Group in CUCM to Saudi arabia-( GMT +03:00)kuwait,
but on my Cisco IP Phones its showing 10 Mints behind from the standard time
Like now on my cisco ip phone its 12:56 pm but current time is 01:06:52 PM, Tuesday 13, April 2010
Please guide me to sort out this issue.
htluo Tue, 04/13/2010 - 06:14
  • Red, 2250 points or more
If it's off for a couple minutes, then it's nothing to do with timezone.
Have you tried to reset the phone?
You may try the following:
1) Find out which CUCM server the phone is registered with.
You may find this information from CUCM > Device > Phone.
2) SSH into the CUCM server you found out in step 1 above/
3) Type command "utils ntp status" and post the output here.
4) Is the time in step 3 the same as the IP phone?
Thanks!
Michael
http://htluo.blogspot.com
