WAP200 looses wifi connectivity in irregular intervals
Apr 13th, 2010
We currently have ~15 WAP200 accesspoints distributed over 4 buildings. Random devices seem to go unresponsive at irregular intervals (web interface still works, clients see a signal, but cannot connect). Rebooting the device solves the problem. User authtication is solved via a radius backend (freeradius), although I highly doubt this is causing the problem since the radius server does not recieve any requests from "broken" accesspoints.
Configuration is WPA2 - Enterprise, only 1 SSID, Power is via PoE
Unfortunately it isn't possible to reliably reproduce the problem. Anyone else having this problem?
sebastianpc Tue, 04/13/2010 - 07:33
Yes, I have only one WAP200E (with PoE) and it pressents the same issue. I have it configured with open security, 1 SSID, I mean with the simpliest configuration and it still looses wifi connectivity. It presents the same sintoms:
I even updated FW from 1.2 to 2.0.0.27.
Attached is the actual config
