Exploration 4 Lab 8.5.1
Answered Question
Apr 13th, 2010
I have been trying to solve this packet tracer lab TroubleShooting Enterprise Networks 1, score 62%.
Below are the modifications that score:
12% DHCP enabled on PC1
7%  config S2 as VTP client
6%  add vlan 30 to S3
6%  add vlan 11 to S3
7%  set no passive-interface S0/0/0 on Router 1
7%  set no passive-interface S0/0/1 on Router 1
6%  set no passive-interface fa0/1 on Router 1
6%  assign port S3 F0/2 to vlan 30
0%  change vtp domain on S3 to CCNA_troubleshooting
6%  add vlan 11 to S3 fa0/1 trunk
There is no check Items, I can't find anything else to fix.
Most appreciate if anyone could help so that I can complete Lab 8.5.2 and Lab 8.5.3 as well.
Correct Answer by jjalexander401 about 6 years 9 months ago
You are missing a passive-int on R1
It doesn't look like you've altered the R2 config in any way.
Some ACLs need attention.
PM me if you want final configs.
Overall Rating: 5 (1 ratings)
Correct Answer
jjalexander401 Fri, 04/16/2010 - 16:10
leepeiwai Sat, 04/17/2010 - 18:44
Yes, I will like to have the final configurations.
I score another 7% by adding another no passive-int on Fa0/0 on R1.
But why do i have to make Fa0/0 non passive, Fa0/0 has no RIP device exists on that LAN therefore no need to send out unneeded updates isn't it?
On R2, i can't tell the purpose of private ACL applied on Lo0. Also not sure the benefits of Anti-spoofing ACL on FA0/1.
NAT statement is strange, tried to modify it to "ip nat inside source list NAT interface Loopback0 overload" but received syntax error.
Thanks for your reply
kriska.martin Sat, 05/29/2010 - 09:46
could you please help me?
I am stuck at 93% (that is 1 item missing) and everything can ping everything.
I think it could be this "R2 must have secure login procedures because it is the Internet edge router"
but I dont know what they want me to configure
tried login local on vty, enable secret, enable password, aaa new-model but still no joy
please I am curios what I missed.
Thank you very much.
Martin
vytautas.alisau... Wed, 04/03/2013 - 12:30
Hi guys, maybe somebody will be interested in activity 8.5.3: I manage to get 93% though /
the answers:
  • S2 fa0/3 switchport trunk native vlan 99                                                 +6
  • S2 fa0/4 switchport trunk native vlan 99                                                 +6
  • S3 create Vlan 11        +6
  • R2 int s0/0/0 no shut        +7
  • PC1 switch to DHCP IP addres                                                           +12
  • R3 int fa0/1.11 encapsulation dot1Q 11                                                  +6
  • R2 int s0/0/1 no shut        +7
  • R2 int s0/0/1 clock rate 400000                                                             +6
  • R2 int fa0/1 no shut        +6
  • R2 router ospf 1 default-information originate                                           +6
  • R2 ip nat inside source list NAT interface FastEthernet0/1 overload          +7
  • R2 int fa0/1 ip nat outside        +6
  • R2 int s0/0/0 ip nat inside        +6
  • R2 int s0/0/1 ip nat inside        +6
Cheers
IkhlasBerrazi Wed, 05/21/2014 - 14:43
Hi jjalexander401
I'm stuck at 75%...
Is it possible to see the final configs?
The exercise is due on friday. :)
Thanks in advance!
Cheers!
Related Content
