AP1131 (Autonomous) 802.11a config for 7921 phones Help
Apr 13th, 2010
I would like to config 802.11a radio of AP1131 (Autonumus mode)  to work with 7921 ip phones. I have some doubts.
In 7921 deployment guide says that i should leave one channel of separation for adjacent AP's. How can i config that in autonomous mode? In 802.11B/G radio i can use comand channel X but und 802.11a interface i only have channel DFS.
I am in Europe what band should i use? Only a UNII-1 channel (channels 36, 40, 44, 48) ?
Is my interface config correct?
interface Dot11Radio1
no ip address
no ip route-cache
encryption vlan 20 mode ciphers tkip
ssid Voice
countermeasure tkip hold-time 0
dfs band 3 4 block
speed  basic-12.0 18.0 24.0 36.0 48.0 54.0
channel dfs
station-role root fallback shutdown
bridge-group 1
bridge-group 1 suno bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
service-policy input data_policy
service-policy output data_policy
!bscriber-loop-control
bridge-group 1 block-unknown-source
Any tips or suggestions would be great!
Best Regards
MC.
dancampb Wed, 04/14/2010 - 11:45
Make sure you add the command "admit-traffic" under the dot11 ssid config.
etmarcof Wed, 04/14/2010 - 11:52
Thanks for you reply but my question is regarding what channels should i use in 802.11a and how to config them in AP1131 in autonomous mode.
dancampb Wed, 04/14/2010 - 11:55
The 7921 supports UNII-1, UNII-2, UNII-2 extended, and UNII-3.  So you really can use any channel.
To configure the channel just:
config t
interface d1
channel <#>
etmarcof Wed, 04/14/2010 - 12:02
In 802.11b/g i can do that:
int dot0
channel #
But in 802.11a
I can only config channel dfs
How can i config channels staticly to config channels separation in adjacent AP's?
I'm in Europe and i saw in 7921 deploy guide that i only have 19 channels available in 802.11a so   it could mean that i souldn't use all UNII-1, UNII-2, UNII-2 extended, and UNII-3.
MC
