Support for LACP short timeouts on N5K
Mar 29th, 2010
Anyone knowns if there is way to configure LACP timeout value. My customer is hitting a bug CSCta60232. Not sure if this bug has been fixed in recent version of NX-OS.
Also what is Cisco recommendation to form vPC. should customers use Active Active on both end of the vPC. If this is true then there might be many compatibility issues with different vendors.
N5K-1# sh lacp  interface ex/y
Interface Ethernet1/4  is individual
  Channel group is 4  port channel is Po4
  PDUs sent: 395402
  PDUs rcvd: 42817
  Markers sent: 0
  Markers rcvd: 0
  Marker response sent:  0
  Marker response rcvd:  0
  Unknown packets rcvd:  44212
  Illegal packets rcvd:  44212
Lag Id: [ [(0,  0-0-0-0-0-0, 0, 0, 0), (0, 0-0-0-0-0-0, 0, 0, 0)] ]
Operational as  aggregated link since Fri Mar 26 14:22:15 2010
Local Port: Ethx/y    MAC Address= 0-d-ec-f2-c9-7c
  System  Identifier=0x8000,0-d-ec-f2-c9-7c
  Port  Identifier=0x8000,0x104
   Operational key=32772
   LACP_Activity=active
  LACP_Timeout=Long  Timeout (30s)
   Synchronization=IN_SYNC
   Collecting=true
   Distributing=true
  Partner information  refresh timeout=Short Timeout (3s)
Actor  Admin State=(Ac-1:To-1:Ag-1:Sy-0:Co-0:Di-0:De-0:Ex-0)
Actor Oper  State=(Ac-1:To-0:Ag-1:Sy-1:Co-1:Di-1:De-1:Ex-0)
Neighbor:  0/0
  MAC Address=  0-0-0-0-0-0
  System  Identifier=0x0,0-0-0-0-0-0
  Port  Identifier=0x0,0x0
  Operational  key=0
   LACP_Activity=unknown
  LACP_Timeout=short  Timeout (1s)  <<<<<<<<<<<<<<  Mismatch in parameters of LACP from Neighbor.
   Synchronization=NOT_IN_SYNC
   Collecting=false
   Distributing=false
Partner Admin  State=(Ac-0:To-1:Ag-0:Sy-0:Co-0:Di-0:De-0:Ex-0)
Partner Oper State=(Ac-0:To-1:Ag-0:Sy-0:Co-0:Di-0:De-0:Ex-0)
Overall Rating: 4 (1 ratings)
Ganesh Hariharan Thu, 04/01/2010 - 11:22
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Anyone knowns if there is way to configure LACP timeout value. My cusotmer is hitting CSCta60232. Not sure if this bug has been fixed in recent version of NX-OS.
Also what is Cisco recommendation to form vPC. should cusotmer use Active Active on both end of the vPC. If this is true then there might be many compatibility issues with different vendors.
  PDUs sent: 395402
  PDUs rcvd: 42817
  Markers sent: 0
  Markers rcvd: 0
   Collecting=true
   Distributing=true
Neighbor:  0/0
  Operational  key=0
   Collecting=false
   Distributing=false
Hi ,
As per the bug detail in cisco sitestill now they have not realesed the fixed in version for this bug and short timeout cannot be configured in nexus 5k.
CSCta60232            Bug Details
Add configurable short timeout to Nexus 5000
Symptom:
The Nexus 5000 does not currently have support to request short timeout.
NOTE: The Nexus 5000 does move to a short timeout when the partner timeout is short. This is because the partner dictates the timeout for the actor. The N5k cannot get the partner to reciprocate due to it not being able to be configured for short timeout.
Workaround:
The channel should still form, but each side is using different timeouts. Whichever timeout is lost first will trigger the channel to re-initialization.
It is recommended to use long-timers on both sides until 4.2(1)N1(1)
Further Problem Description:
To identify the partner timeout:
sho lacp interface eth X/Y
Neighbor: 0/0
Operational key=0
LACP_Timeout=short Timeout (1s)<<<
Collecting=false
Distributing=false
Status
Fixed
(Resolved)
Severity
3 - moderate
Last Modified
In Last 3 Days
Product
Cisco Nexus 5000 Series Switches
Technology
1st Found-In
4.1(3)N1(0.164)
Fixed-In
Release-Pending
Component(s)
lacp
Hope to Help !!
Ganesh.H
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
krunal_shah Tue, 04/13/2010 - 05:47
Actual issue is related to N5K not accepting the LACP size not more then 128 bytes long. If anyone using simlar version of code and having same issue.
Use debug lacp packets and see following message will apear on the switch.
2010 Apr  1 17:27:58.215418 lacp: lacp_net_rx_data(242): Rcvd BAD PDU: Sanity failed: if_idx 0x1a00e000: pkt_len 128
Also in show lacp interface eth x/y will show illegal packets counter increasing rapidly.
This issue id related to software bug :
CSCtg01091 Accept LACPDU's that exceed 128B standard length
Above bug should be fixed in 4.2 code.
kribrath Tue, 02/21/2017 - 22:49
Hi!
I know this is an outdated post, but it comes up again in my network this year, theres a setting in Windows 2012Server enviroment that can change this behavior.
https://support.microsoft.com/en-us/help/3109099/update-adds-support-for-the-slow-timer-in-lacp-in-windows-server-2012-r2
Fast LACP is not compatible with ISSU (In service software upgrade) and this hotfix should be done on servers before performing an ISSU.
//BR
Kristian
