WIPT survey
Apr 13th, 2010
Hey Expert
i have downloaded AIRMAGNET  survey & planner  and netstublmer is there any other software which  i missing for conducting my WIreless Survey
Kindly suggest me
Thanks /Regards
chad_teal Tue, 04/20/2010 - 12:51
You have the software you need but I'm not sure what type of survey you are doing.  The Planner module is for a predictive survey while the Survey application is used to perform the actual survey.  You don't really need netstumbler.  Survey will give you all the information you need.  The biggest step that is often skipped in a wireless design is determining design requirements before the survey.  You can't design a network if you don't know what you are designing the network to do.  There is a lot more to surveying than putting one AP up on a wall and walking around.  You need to figure out what you are trying to do and then plan your survey around that information.  Let me know if you need additional assistance.
Faizan Khursheed Wed, 04/28/2010 - 00:46
i m doing voice over wirless survey as well as data  can u guide what standard should i use for for voice
should i use 802.11a for voice because it has less interference and 802.11b/g for data
Waiting for your prompt response
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
