Find Unity version/patch level.
Answered Question
Apr 13th, 2010
New guy, old install.  I need to find the version that I'm running as well as where to find patches/updates.
I searched my brains out, but found only the upgrade guides and Windows patching Wizards.
Thanks!
Correct Answer by David Hailey about 6 years 10 months ago
On the Unity server, there is a tool in the Unity Tools Depot called Gather Unity System Info (GUSI).  Run this tool and it will give you the exact version and patch rev of your system.  You can download patches and updates via CCO account on Cisco.com - Support - Downloads - Unified Communications.
Hailey
Please rate helpful posts!
Overall Rating: 5 (2 ratings)
Aaron Harrison Tue, 04/13/2010 - 06:59
It you don't know the product well enough to work out what version you are on, you probably shouldn't meddle?
The version you have is displayed on the admin interface when you log in.
You can download the server updates wizard that you've seen already to bring your MS patching up to date...
Aaron
Please rate helpful posts...
Correct Answer
David Hailey Tue, 04/13/2010 - 07:00
Hailey
