NAC with RADIUS
Answered Question
Apr 13th, 2010
¿Does Cisco NAC solution for LAN supports another RADIUS server different than Cisco ACS?
Correct Answer by Faisal Sehbai about 7 years 1 month ago
Jonathan,
I assume you mean Radius for the auth providers? If so, any standard Radius server should do.
HTH,
Faisal
Overall Rating: 5 (1 ratings)
Correct Answer
Faisal Sehbai Tue, 04/13/2010 - 09:32
  • Gold, 750 points or more
Jonathan,
HTH,
Faisal
solerj Tue, 04/13/2010 - 09:35
I mean the Radius server that it is necessary for authenticating internal users in the LAN (integrated with AD), and for applying NAC policies.
Faisal Sehbai Tue, 04/13/2010 - 09:39
Jonathan,
You're talking about IAS, the free Radius server that comes with the Windows? If so, then yes, that would work too. On CCA you use Radius in a couple of places - Either as an Auth Provider, or if you're doing VPN SSO, as an Accounting server. In both instances it should work fine.
HTH,
Faisal
