SA520 multiple remote networks behind one tunnel
Apr 13th, 2010
Hi guys,
Since the ASA5505 is backordered everywhere I figured I'd give one of these mosters a try.
Problem is, I can't see an obvious way to support multiple networks behind a single VPN tunnel.  Need to do 192.168.128/23, 192.168.192/23 and 172.20.0/23, but can only do one.
Is this possible?  If not I guess I'll return this and wait for the 5505.
Jason
biraja Tue, 04/13/2010 - 15:22
Hi Jason,
Multiple remote networks behind one tunnel is not supported with SA500 as of now.
Biraja
jslagle Tue, 04/13/2010 - 19:04
I actually did eventually get it to work using multiple VPN Policies with one IKE policy.  My worry now is about the stability of the device.  Lots of complaints here about that.
I'm not using any remote VPN features, but I am using multiple remote networks.  Can anyone else give any insight into stability pushing 5mbps of traffic or so?  30ish users.
Jason
biraja Wed, 04/14/2010 - 10:09
Hi Jason,
I recommend you to try out the new release which will be released in a day or two.
There are significant performance improvements for site-to-site VPN and majority of the issues are fixed.
Biraja
