hi need help for failover
satishsingh_24
can any one help me.
> We have designed solution using Cisco router, where customer
> > > > > have
> > taken
> > > > > internet link from isp and terminated the same on fasthernet 1
> > > > > and
> LAN
> > > is
> > > > > connected is to fastethernet 0.
> > > > > And he have taken ADSL link also and terminated it on another
> > > > > ADSL
> > > router
> > > > > and LAN he connected to same switch and kept the LAN ip
> > > > > address on
> > ADSL
> > > > same
> > > > > as Cisco router LAN ip address.
> > > > > why he have this because ,he want when primary link goes down
> > > > > then
> > > traffic
> > > > > has to shift to ADSL link ,it happening also ,but when primary
> > > > > link
> > come
> > > > up
> > > > > ,it does not move to primary link ,still the traffic used to
> > > > > route
> > > through
> > > > > ADSL link and once we used to enable or disable the LAN card
> > > > > then it
> > > move
> > > > > the traffic through primary .
> > > > > Please refer the document and suggest me the same.
Rick Morris
Level 6
Level 6
Here you have a couple of ways to set this up.
You can use HSRP or if your router is capable GLBP.
You could also use static routing with a higher AD on the secondary link.
11 Replies 11
Rick Morris
Level 6
Level 6
please check then document and as failover is working ,but recovergance is not happening .
mean router is able to shift from primary to secondary ,but not able to shift again secondary to primary.
The config you have states router, what is on the switch?
Is this a layer 3 switch?  If you want failover to work you need the routing on the switch to direct the traffic.
My suggestion still would be to use HSRP and make sure you add preempt so the main router will take back over once the main line restores.
Here is a link to HSRP configs.
http://www.networkstraining.com/cisco-router-hsrp-configuration/
I checked the attached document and providing very correct information. Only information
it missing is that whether ADSL router is maintained by you or maintained by Service provider.
By looking at the scenario HSRP with preempting enable appears to be simplistic proven option.. even HSRP advance feature like interface / IP tracking provdies IP tracking also..
This will help you to configure the expected result..
Hope this helps you..
cheers!
Shailesh
adsl will going to maintain by isp and it have only static route configured on it pointing toward wan .
if you have any configuration sample available with you ,please share the same
I am giving one of sample configuration
ip sla monitor 1
  type echo protocol ipIcmpEcho 10.10.10.1
ip sla monitor schedule 1 life forever start-time now
track 1 rtr 1 reachability
ip route 10.10.10.0 255.255.255.0 (isp1-ip) track 1
ip route 10.10.10.0 255.255.255.0 (isp2-ip) 250
With regards,
Shailesh Hardas
tried all thing ,but it does not working ,the same thing is working on another router
below is detail of configuration
sh ver
Router#sh version
Cisco IOS Software, 1841 Software (C1841-SPSERVICESK9-M), Version 12.4(7c), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 18-Sep-06 19:29 by alnguyen
ROM: System Bootstrap, Version 12.3(8r)T9, RELEASE SOFTWARE (fc1)
Router uptime is 25 minutes
System returned to ROM by reload at 13:53:29 UTC Thu Apr 15 2010
System image file is "flash:c1841-spservicesk9-mz.124-7c.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
--More--                           http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
export@cisco.com.
Cisco 1841 (revision 6.0) with 117760K/13312K bytes of memory.
Processor board ID FHK105112MG
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Router#sh run
Router#sh running-config
Building configuration...
Current configuration : 841 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
--More--                           ip sla monitor 1
type echo protocol ipIcmpEcho 192.168.2.2
timeout 1000
threshold 2
frequency 3
interface FastEthernet0/0
ip address 192.168.2.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.1.5 255.255.255.240
duplex auto
speed auto
--More--                           ip route 0.0.0.0 0.0.0.0 192.168.2.2 track 1
ip route 0.0.0.0 0.0.0.0 10.1.1.1 10
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
Router#
this one also tried
SH RUN
Current configuration : 1263 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
--More--                           ip dhcp pool satish
   network 10.1.1.0 255.255.255.240
   default-router 10.1.1.5
ip sla monitor 1
timeout 1000
threshold 2
frequency 3
ip route-cache policy
ip route-cache flow
duplex auto
--More--                            speed auto
ip route-cache flow
duplex auto
speed auto
ip local policy route-map DEFAULT-ROUTE-POLICY
no ip http server
access-list 101 permit icmp any host 192.168.10.2 echo
route-map DEFAULT-ROUTE-POLICY permit 1
match ip address 101
set interface Null0
set ip next-hop 192.168.2.2
--More--                           !
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Router#
please check out the file ,it rar file ,so please delete  txt extension then you will be able to check it out
Are you using a layer 3 switch?
If so then set up HSRP on the routers:
In your switch point your default gateway to the virtual IP being used for HSRP.
One important step is to make sure on the primary router you have preempt applied so when the primary link becomes available it will assume the role as primary again.
If you do a search in cisco.com you will find other examples too.
With what you have below it is not set-up very well.  You are taking your traffic to one router then when the link goes down that primary router then sends the traffic to the other router.  This step should be done on the switch, with a little help with the HSRP set-up.
I would post a traceroute from a host to confirm but I am pretty sure that is what is happening here.
it unamanged layer 2 switch ,so no option to define hsrp and another thing i have only one cisco router and another router is from k adsl router .so on it does not have option to define HSRP .
please suggest any other way if you can think .
If you have access to the DSL router then set up VRRP
This is the same thing as HSRP, but NOT cisco only.
Here is a link to the sample config.
The vip will be the default gateway for the clients.
http://inetpro.org/wiki/VRRP_Configuration
hi sir
adsl router does not have option to define vrrp .
any other way to do the same
