Use of Time in UCCX scripting
Answered Question
Apr 13th, 2010
    We are working on UCCX7.0(1) and have a scripting question. The requirement I have is to play a prompt for a defined set of time, say 5 minutes, in a loop. On the expiry of the time, the call should end. Following is the steps that I need to achieve-
1) Play a message , Prompt1, asking the user to enter a digit.
2) On timeout or invalid entry, loop through the Prompt1 unlimited number of times.
3) But once the duration of the play reaches 5 minutes, end the call.
I am not aware of checking this timer/duration within the script. This seems pretty basic but Iam a novice to scripting, so any help is highly appreciated.
DM
Correct Answer by Anthony Holloway about 7 years 2 weeks ago
i don't fully understand what you need but here is an example that may get you going in the right direction.  keep in mind that ending the script at exactly 5 minutes will be nearly impossible, unless you can control exactly how long the prompt playback lasts.  i.e.g, 30 second prompt, loops 10 times.
Pseudo Code
set start_time = d[now].getTime()
label loop_prompt_playback
play prompt(--triggering contact--, p[some_prompt])
set current_time = d[now].getTime()
if (current_time - start_time < 300000)
     true
          goto loop_prompt_playback
     false
terminate(--triggering contact--)
end
Overall Rating: 5 (1 ratings)
Correct Answer
Anthony Holloway Wed, 04/14/2010 - 10:30
  • Purple, 4500 points or more
Pseudo Code
     true
     false
end
dmurthy74 Wed, 04/14/2010 - 13:24
It works!! You are right, I will not be able to time it to exactly 5 minutes but the customer is fine with it.
I just had to tweek the code a tiny but in oder to compare 2 Long values :
if (EndTime - StartTime) >= (300000.longvalue()) then
     Goto End
Else
     Goto Prompt_Label.
Thanks a ton!!
DM
