Cisco 871: Allow two VLANs to access one another
Apr 13th, 2010
We are using a Cisco 871 in our data center, which is configured with  two VLANs as follows:
- VLAN1 contains FastEthernet0,  1, and 2, has an IP address of 192.168.1.1, and is associated with  network 192.168.1.0/24
- VLAN2 contains FastEthernet3, has an IP  address of  192.168.101.1, and is associated with network 192.168.101.0/24
At  present, I am able to ping all devices on both subnets from the Cisco  router. However, from a machine that is connected to the 192.168.1.0  network, I can only ping 192.168.101.1 (the IP address of VLAN2).  Ideally, I would like to be able to access any IP address on the  192.168.101.0 network when using a computer that is connected to the  192.168.1.0 network, and vice versa. Does anyone have any idea how this  can be accomplished?
Any help would be greatly  appreciated!
Best Regards,
Steven
Leo Laohoo Tue, 04/13/2010 - 19:00
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
What's the config for both?
itlengineering Tue, 04/13/2010 - 19:40
Here are the configs for both Vlans:
interface Vlan1
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Vlan2
ip address 192.168.101.1 255.255.255.0
ip nat inside
ip route 192.168.1.0 255.255.255.0 Vlan1 permanent
Is this what you were looking for? If you require more information, please let me know.
lamav Tue, 04/13/2010 - 19:14
  • Blue, 1500 points or more
It sounds like you're trying to PING PC's and it's not working. Make sure that they do not have a firewall enabled.
Victor
itlengineering Tue, 04/13/2010 - 19:43
Hi Victor,
Actually, the devices I am trying to ping are not computers but IP phones, and as such they have no firewall. Also, I am able to ping these phones from any machine that resides on the 192.168.101.0 network, and I can ping these phones from the Cisco, so I don't think it's a firewall issue.
Also, there is no firewall currently set up on the Cisc. Perhaps its an ACL problem?
Leo Laohoo Tue, 04/13/2010 - 20:32
  • Hall of Fame,
    2017 LAN, Wireless
Can you post the "sh run" of both routers?
lamav Tue, 04/13/2010 - 20:42
Yes, please post the configs...
itlengineering Tue, 04/13/2010 - 20:49
Thanks for your reply. Just to clarify, there is only one router  (with two VLANs) in this configuration. The sh run of this router is as  follows:
Building configuration...
Current configuration : 21858 bytes
version 12.4
no service pad
hostname Engineering
boot-start-marker
boot-end-marker
logging message-counter syslog
logging buffered 51200 warnings
enable secret 5 $1$c03E$wjKfvdU9usL1o5lJkJ/ij.
aaa new-model
aaa authentication login default local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network sdm_vpn_group_ml_1 local
aaa session-id common
clock timezone jst 9
dot11 syslog
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.100
ip dhcp excluded-address 192.168.1.200 192.168.1.254
ip dhcp pool sdm-pool
    import all
    network 192.168.1.0 255.255.255.0
    default-router 192.168.1.1
    dns-server 192.168.1.9 192.168.1.200
    lease 0 8
ip cef
ip name-server 202.224.32.2
ip name-server 202.224.32.1
archive
  log config
   hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
  switchport access vlan 2
interface FastEthernet4
  description $ETH-WAN$
  ip address dhcp client-id FastEthernet4
  ip mtu 1454
  ip nat outside
  duplex auto
  speed auto
  pppoe-client dial-pool-number 1
interface Vlan1
  description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
  ip nat inside
interface Vlan2
  ip nat inside
interface Dialer0
  description $FW_OUTSIDE$
  ip mtu 1454
  ip nat outside
  encapsulation ppp
  dialer pool 1
  dialer redial interval 30 attempts 1000 re-enable 300
  dialer-group 1
  no cdp enable
  ppp authentication chap pap callin
  ppp chap hostname ********
  ppp chap password 0 ********
  ppp pap sent-username ********
ip local pool SDM_POOL_1 192.168.9.101 192.168.9.250
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0 2
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
logging 192.168.1.200
access-list 100 remark SDM_ACL Category=4
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 remark SDM_ACL Category=2
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 101 permit ip 192.168.9.0 0.0.0.255 any
access-list 101 permit ip 192.168.101.0 0.0.0.255 any
no cdp run
route-map SDM_RMAP_1 permit 1
  match ip address 101
control-plane
banner login ^CCCC
Cisco Router and Security Device Manager (SDM) is installed on this  device.
This feature requires the one-time use of the username "cisco"
with the password "cisco". The default username and password have a  privilege
level of 15.
Please change these publicly known initial credentials using SDM  or the IOS
CLI.
Here are the Cisco IOS commands.
username   privilege 15 secret 0
no username cisco
Replace and with the username  and password you want to
use.
For more information about SDM please follow the instructions in  the QUICK
START
GUIDE for your router or go to http://www.cisco.com/go/sdm
^C
line con 0
  no modem enable
line aux 0
line vty 0 4
  transport input telnet ssh
scheduler max-task-time 5000
end
Thanks for  your help! If you have any other questions, please let me know.
Steven
Leo Laohoo Tue, 04/13/2010 - 21:07
  • Hall of Fame,
    2017 LAN, Wireless
Where's your route for VLAN2?
itlengineering Tue, 04/13/2010 - 21:30
I just ran the following command from the router CLI:
ip  route 192.168.101.0 255.255.255.0 Vlan2 permanent
However,  I still cannot ping any 192.168.101.0 devices from the 192.168.1.0  network. Is the above command what you had in mind? If not, please let  me know.
Steven
Shahaludeen N Tue, 04/13/2010 - 21:57
Hi Steven,
If you are able to ping the IP phones from the router itself, layer2 reachability is there. I assume the subnet for IP phones is 192.168.101.0/24 based on your explanation and if so I can see the IP phones are getting the IP address not from the router as there is no pool configured for 192.168.101.0/24 subnet and so I am not sure the IP phones are using the correct default gateway. You have to use the 192.168.101.1 as the default gateway on the IP phones if that is your assumed gateway, then only it can reach network beyond their own.
Shahal.
itlengineering Wed, 04/14/2010 - 00:53
I changed the gateway of one phone to 192.168.101.1, and then I was  able to ping it from a machine on the 192.168.1.0 network! Thanks for  that!
However, now I have run into a different problem.  The phone was previously using 192.168.101.252 as its gateway in order  to communicate with the SIP network, which resides at IP address  220.157.32.78. This IP address is only accessible through gateway  192.168.101.252. Since the gateway value on the phone has now been  changed to 192.168.1.1, the phone is no longer able to access  202.157.32.78 through SIP gateway 192.168.101.252. In an attempt to  overcome this, I created a static route using the follwoing CLI command:
ip  route 220.157.32.78 255.255.255.255 192.168.101.252 permanent
However,  this did not seem to have any effect. Is it possible to configure the  Cisco router to always route traffic directed at 202.157.32.78 through  192.168.101.252.
Steven
