Rv082 logs
teststation3
Hi, I mention that none 86.126.128.46 and 86.121.209.115 are not my IP's (same ISP provider)...Why this entry is logged (firewall log) by my router rv082?.
If ip1 want to make vpn to ip2 ..why they pass trough my router..and looks like an attack..
Can anybody tell?
Apr 14 07:32:30 2010    Connection Refused - Policy violation   TCP 86.126.128.46:56373->86.121.209.115:1723 on ixp2
Apr 14 07:32:31 2010     Connection Refused - Policy violation   TCP  86.126.128.46:56373->86.121.209.115:1723 on ixp2
Apr 14 07:33:02 2010     Connection Refused - Policy violation   TCP  86.126.128.46:56702->86.121.209.115:1723 on ixp2
Apr 14 07:33:12 2010     Connection Refused - Policy violation   TCP  86.126.128.46:56702->86.121.209.115:1723 on ixp2
Apr 14 07:33:17 2010     Connection Refused - Policy violation   TCP  86.126.128.46:56702->86.121.209.115:1723 on ixp2
Apr 14 07:33:34 2010     Connection Refused - Policy violation   TCP  86.126.128.46:56982->86.121.209.115:1723 on ixp2
Apr 14 07:33:47 2010     Connection Refused - Policy violation   TCP  86.126.128.46:56982->86.121.209.115:1723 on ixp2
Apr 14 07:33:57 2010     Connection Refused - Policy violation   TCP  86.126.128.46:57182->86.121.209.115:1723 on ixp2
Apr 14 07:34:52 2010     Connection Refused - Policy violation   TCP  86.126.128.46:57643->86.121.209.115:1723 on ixp2
Apr 14 07:35:44 2010     Connection Refused - Policy violation   TCP  86.126.128.46:58120->86.121.209.115:1723 on ixp2
Apr 14 07:36:02 2010     Connection Refused - Policy violation   TCP  86.126.128.46:58355->86.121.209.115:1723 on ixp2
Gerald Vogt
Level 3
Level 3
Someone tries to connect to the PPTP server on 86.121.209.115 but the RV blocks it. They don't pass through your router. It's blocked.
If 86.121.209.115 really is not your IP address then your ISP would have a serious routing issue. You should never see any traffic not indented for your router. Thus better doublecheck that 86.121.209.115 really is not your IP address.
How do you connect to the internet? Do you use a PPTP or PPPoE internet connection?
teststation3
i have sent a email to ISP
Gerald Vogt
Level 3
Level 3
I have a leased line...fiber..5mbp for internet connection 2 . The rv082 is a load ballancer with 2 different ISP's.
The firewall log is quiet now,  since my email to ISP. I think also they have a routing problem. I expect a answer from them and I will post'it.
Tx for tip'
