Cisco IAD 2430
Apr 13th, 2010
Hi All,
Does anyone know if IAD 2430 voice gateways are supported with CCM 4.2?
I would like to get a replacement for a VG224. Is there any other 24 Port FXS port SCCP/MGCP gateways available except Vg224 and cat 6000.
Thanks for your help
Mohammed
Overall Rating: 2 (1 ratings)
Aaron Harrison Wed, 04/14/2010 - 00:44
  • Community Spotlight Award,
    Member's Choice, May 2015
Hmmm.. why not a new VG224?
Aaron
mnour401917_2 Wed, 04/14/2010 - 00:51
Aaron,
They are too expensive for the customer. I'm investigating an alternative solution if there is any???
Mohammed Nour
Aaron Harrison Wed, 04/14/2010 - 01:38
Unless they have a much less than 24 port count I'm not sure what else you could go for whilst maintaining good supportability...
Aaron
mnour401917_2 Wed, 04/14/2010 - 01:44
Aaron,
Thanks for the information. My other question was if the IAD 2430 are supported with CCM 4.2? do you know if these gateways are supported? They support SIP, MGCP and H323, but I couldn't find any document that shows which version of CCM supports the IAD 2430 Voice gateways. Thanks for your help anyway.
Mohammed Nour
Aaron Harrison Wed, 04/14/2010 - 02:13
I've never used that piece of kit, but can tell you it appears in my CallManager v7 and v8 admin pages to allow adding it as MGCP (but not SCCP). Generally if something supports h.323 it will probably work as CCM isn't aware of the specific hardware type of the gateway.
Someone else may be able to advise you on real life experience with that equipment...
Aaron
mnour401917_2 Wed, 04/14/2010 - 03:01
Thanks again. It has to support MGCP/SCCP for my requirement.
I was more asking specific to CCM 4.2 if there is a patch for it.
Checking the available GW to add on CCM 4.2 doesn't show IAD 2430 but the old 2420, Another CUCM 7.1.3 I have shows IAD 2400, but not 2430.
Mohammed Nour
