David Hailey Tue, 04/13/2010 - 23:15
  • Purple, 4500 points or more
Reboot the server.
Hailey
Please rate helpful posts!
bilalsheikh Tue, 04/13/2010 - 23:21
Thnx David, one more thing is there any way to increase the virtual memory.
william_chua Tue, 04/13/2010 - 23:35
I had this same issue before with CUCM version 6.1.2.
Yes, rebooting the server will resolve the issue. However, eventually, the issue will reoccur.
As a permanent solution, upgrade your CUCM version to 6.1.3 or later. This issue is bug related.
Aaron Harrison Wed, 04/14/2010 - 00:42
  • Community Spotlight Award,
    Member's Choice, May 2015
Yeah, agreed... I've seen lots of memory leak type bugs in the early 6.0 releases. Can't remember the specifics unfortunately, but options are really limited to reboots to work round it, or upgrades to fix as you don't have access to tweak any real OS parameters.
Aaron
Please rate helpful posts..
