Cannot remark DSCP 0 on Catalyst 3750
Apr 14th, 2010
I’ve got Catalyst 3750 switch. On the ingress port (Gi1/0/4) I am receiving lot of traffic from some Voice equipment.  This is the configuration:
interface GigabitEthernet1/0/4
description "media"
switchport access vlan 113
switchport mode access
service-policy input MEDIA
policy-map MEDIA
  class MEDIA-SPC
   set dscp cs2
  class MEDIA-RTP
   set dscp cs5
class-map match-all MEDIA-SPC
  match ip dscp af11
class-map match-all MEDIA-RTP
  match ip dscp default
I want to remark AF11 to CS2. And this works just fine. ( I can see the packets correctly marked when leaving the switch (uplink monitored with Wireshark).
I would like also to remark DSCP 0 to DSCP 40 (CS50) but the switch doesn’t remark that as expected.
Does anyone know why I can remark AF11 and I cannot do the same for DSCP0?
Franjo
Franjo Pongrac Fri, 04/16/2010 - 01:03
CRI31#show mls qos
QoS is enabled
QoS ip packet dscp rewrite is enabled
CRI31#show mls qos maps ip-prec-dscp
   IpPrecedence-dscp map:
     ipprec:   0  1  2  3  4  5  6  7
       dscp:   0  8 16 24 32 40 48 56
CRI32#
CRI32#show mls qos maps ip-prec-dscp
Franjo Pongrac Fri, 04/16/2010 - 03:13
I actually configured it this way but in sh running-configuration you see it as CS5. So it is only how IOS prefers to display binary value 101 000.
mlund Fri, 04/16/2010 - 03:33
  • Silver, 250 points or more
Hi Franjo
The "match ip dscp default" actally means "match ip dscp 0"
There are a very high chance that the rtp-streams already are marked with some dscp-value (normally 40 or 46), and therefore are not matched.
Try to match something else in the "class-map match-all MEDIA-RTP",  "match dscp 40" or "match dscp 46" or maybe "match any" , if the stream already are marked with dscp 40 you don't need to rewrite it.
/Mikael
Related Content
