How to view & verify object-group
Answered Question
Apr 14th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If we run show object-group command, it will list down all the object-group on the firewall.
Pix(config)# show object-group
object-group network dmz_servers
  description: The DMZ shared servers
  network-object host 192.168.2.3
  network-object host 192.168.2.4
  network-object host 192.168.2.5
object-group network Partners
  description: The dealer and supplier partners
  network-object host 172.16.21.119
  network-object 192.168.7.0 255.255.255.0
  network-object 192.168.12.0 255.255.253.0
Is there any specific command how to show only specific object-group?
As example, if I only want to get what is inside dmz_servers only, which command should I use?
I’ve tried
show object-group dmz_servers
Show object-group network dmz_servers
But didn’t work. Please advice. Thanks
Correct Answer by Kureli Sankar about 6 years 8 months ago
You need to issue either
sh run object-group service
or
sh run object-group id Port_ABC -------> watch the "id" keyword
-KS
Overall Rating: 5 (3 ratings)
Jennifer Halim Wed, 04/14/2010 - 02:31
  • Cisco Employee,
Unfortunately you won't be able to show just that particular object.
The closest you can do is to list that particular object on top of your show output as follows:
sh run object-group network | b Partners
Hope that helps.
CCL Network Ser... Thu, 06/25/2015 - 11:23
i wonder why this feature is not added,as  it is becoming a nightmare to find exact NAT statement for a particular IP's esp.when you have thousands of object statements. CLI is becoming unmanageable
Panos Kampanakis Wed, 04/14/2010 - 16:03
  • Cisco Employee,
You can do it using
show object-group network id dmz_servers
I hope it helps.
PK
Adam David Wed, 04/14/2010 - 19:09
thanks halijenn & pkampana for your reply.. forgot that ASA & PIX differ a little bit in their command.
Btw, this is the correct command to view specific group in both ASA & PIX
# ASA
sh run object-group id dmz_servers
# PIX
show object-group id dmz_servers
Adam David Sun, 10/17/2010 - 02:59
Hi all,
The command above can be used to verify object-group in ASA. But it won’t work against the object-group for service as below. Any advise in this matter would be highly appreciated.
The command below failed.
ASA5510# sh run object-group service Port_ABC
ERROR: % Invalid input detected at '^' marker.
This object-group actually exist on the firewall
object-group service Port_ABC tcp
port-object eq 2000
port-object eq 2111
port-object eq 2222
ASA5510# sh run object-group ?
  icmp-type  Show 'icmp-type' type of object group(s)
  id         Show specific object group
  network    Show 'network' type of object group(s)
  protocol   Show 'protocol' type of object group(s)
  service    Show 'service' type of object group(s)
  |          Output modifiers
ASA5510# sh run object-group service ?
  |  Output modifiers
Correct Answer
Kureli Sankar Sun, 10/17/2010 - 06:10
  • Cisco Employee,
or
-KS
Adam David Sun, 10/17/2010 - 06:16
Thanks again Kusankar for your help. How come I can miss "id" there . No wonder it never works.
yenaungoo Wed, 11/13/2013 - 19:10
Hi Anyone can suggest how many IP addresses can configure under a object-group network? (ASA 5550 ver 8.2)
My customer wants to configure 6000 IPs under a object-group and add the deny rule for this group.
Thanks ahead,
