Importand sync the Switch hosts/IP’s From The LMS to the ACS
albatli1977
I Need to Importand sync the Switch hosts/IP’s From The LMS to the ACS For Create more than one ( Network Devices Group ) on the ACS Coz The Configuration of the ACS server Now is Configured as *.*.*.* ( AAA Client IP Address ) with the IP Address Of the ACS As ( AAA server IP Address ) only.
ACS is (Release 4.0(1) Build 49 ) under Microsoft OS.
LMS 3.2 under solaris 9 with fully integartion with ACS
No.  The user-defined fields are unique to LMS, and cannot be pushed to ACS.  You can push the devices themselves from LMS to ACS using the dcrcli command I mentioned previously.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
5 Replies 5
Joe Clarke
Are you wanting to create more NDGs for logical separation of management tasks, or are you seeing the *.*.*.* wildcard not work?  If you want to logically segment your devices into multiple NDGs, you will first need to remove the *.*.*.* entry, then create the desired NDGs, and manually add the devices to them.  If, however, you want to explicitly list all devices out in ONE NDG, you can use the dcrcli expAcs command to send all devices from LMS to ACS into one NDG.  For example:
dcrcli -u admin cmd=expAcs hn=acs1.company.com un=admin pwd=admin prt=2002 proto=http seckey=mySecret ndg=MyNDG
Ok ,we are wanting to create more NDGs for logical separation of management  tasks.
Is there any way to sysnc between user files in LMS and NDGs Iin ACS?....
What do you mean, "user files in LMS?"
Sorry, I mean "User Defined Fields" in Ciscoworks
