VSS logs Interpretation
Answered Question
Apr 14th, 2010
Below is the an output from terminal monitor in my VSS 6506 Switches.
Please help me interprate what could be going wrong here.
Apr 10 07:20:09.701: DFC1: Switch mode info  received by DFC..!
000139: Apr 10 07:20:11.185: %SYS-DFC1-5-RESTART:  System restarted --
Cisco IOS Software, c6lc2 Software (c6lc2-SP-VM),  Version 12.2(33)SXI3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 26-Oct-09 23:13 by prod_rel_team
Apr 10 07:20:11.437: DFC1: Currently running ROMMON  from S (Gold) region
000140: Apr 10 07:20:30.853 UTC:  %DIAG-SW1_SPSTBY-6-DIAG_OK: Switch 1 Module 1: Passed Online Diagnostics
Apr 10 07:20:37.007 UTC: SW2_SP:  Card inserted in Switch_number = 1 ,
                physical slot 1, interfaces are now online
000141: Apr 10 20:49:58.843 UTC: SSH2 0: Unexpected  mesg type received
000142: Apr 11 20:49:28.860 UTC: SSH2 0: Unexpected  mesg type received
000143: Apr 12 20:48:59.426 UTC: SSH2 0: Unexpected  mesg type received
000144: Apr 13 04:34:07.426 UTC: SSH2 0: Unexpected  mesg type received
Correct Answer by Giuseppe Larosa about 7 years 3 months ago
Hello Hassan,
from experience usually this kind of events lead to a linecard change if it happens multiple times.
The impact is confined to that linecard not to the whole device.
So keep an eye on it: if it happens other times try to have the linecard extracted and then reseated firmly.
IF it is not enough it is time for an RMA of the linecard
To be noted if someone issued the "appropriate" command the module had been reset and you can see this kind of messages as well as a result of the given command.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Wed, 04/14/2010 - 08:08
  • Hall of Fame,
    Founding Member
Hello Hassan,
the linecard on slot 1 a 67xx module with a DFC has been restarted and some messages come from the DFC daughter card
is the module up and running now?
you can check this with sh module
you can look in log buffer with sh log if there are errors related to module 1 before the restarting. The supervisor can have forced a reload because for example the linecard didn't answered to keepalives that are sent on the backplane to check modules health.
Has this happened only once or more times?
Hope to help
Giuseppe
Hassan Mwangi Sat, 04/17/2010 - 10:06
Hello Giuseppe,
This is from one of our clients and he was concerned about the error.
The module is up and running.
We could not find any useful information from the logs.
But i was wondering if this can affect the functionality of the switch or could even lead to a failure.
We are not sure as this came when he was logged on to the switch.
Hassan.
Correct Answer
Giuseppe Larosa Sat, 04/17/2010 - 13:31
  • Hall of Fame,
    Founding Member
Hello Hassan,
Hope to help
Giuseppe
Hassan Mwangi Tue, 04/20/2010 - 08:40
Hello Giuseppe,
Thanks so much for you help.
If any adverse thing happens i will surely consult you.
