Two Contact Center 7.0
Answered Question
Apr 14th, 2010
Is possible, install two ipcc on same call manager without high availability between they. I know of the all details about design, but i would like the know if is possible.
Correct Answer by Aaron Harrison about 6 years 11 months ago
Yes, you can have multiple UCCX clusters with one CCM cluster.
The only thing my customer complained about was that there is only one 'IPCC Extension' setting. When you set this, that agent will appear in both UCCX clusters admin interfaces... so you can get larges lists of resources in the AppAdmin pages and so on.
Aaron
Please rate helpful posts...
Overall Rating: 5 (2 ratings)
Correct Answer
Aaron Harrison Wed, 04/14/2010 - 04:56
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
w.pimentel Wed, 04/14/2010 - 05:42
Aaron
Thank very much, the CTI ports must be differ ?
Aaron Harrison Wed, 04/14/2010 - 05:44
Absolutely.
The two CCX servers must have separate JTAPI/RMJTAPI accounts, separate CTI Ports, separate CTI Route points...
Aaron
