IP Helper on WAN/LAN
Answered Question
Apr 14th, 2010
I have the scenario attached, this scenario the wan is frame-relay
My question is how can a DHCP server remote identify what POOL of IP address to use?
I know I can use a local dhcp server, even the router as dhcp server,  but the centralized dhcp is a requirement :/
Correct Answer by shailesh.h about 6 years 11 months ago
i think attached document will provide you more information
http://h40060.www4.hp.com/procurve/uk/en/pdfs/5300xl_dhcp_relay.pdf
Shailesh
Correct Answer by Paolo Bevilacqua about 6 years 11 months ago
It know because the router insers GW address in the request packet.
Be aware that when WAN is down, the "requirement" becomes a major hinderance, and everyone gets very angry.
Overall Rating: 5 (2 ratings)
Correct Answer
Paolo Bevilacqua Wed, 04/14/2010 - 05:38
  • Hall of Fame,
    Founding Member
Rodrigo Gurriti Wed, 04/14/2010 - 05:52
For instance,
Will F1 forward the dhcp discovery from a workstation to the DHCP server using as source address F1's local ethernet? Is that how it knows ? or is there a option that it uses ?
Thank you!
