Not showing user busy on Cisco IP Phones.
Apr 14th, 2010
I have a cluster of CUCM 7 (Publisher and Subscriber) ,i configured Voice gateway  h323 with 8 fxo ports
Internal  using 4 digits ,Local .International dialling is enabled.
Users are calling internally to each other by using 4 digits but the problem is that when the user is busy on the phone and  if other user is calling to him the bell is ringing but the calling party doesn't know that he is busy with another call.
I want to setup some configuration that if the user is already busy on the line and if anybody alse called to same user he should see that he is busy on the phone OR something same like this.
How i can configure this on CUCM. ?????
Aaron Harrison Wed, 04/14/2010 - 05:27
  • Community Spotlight Award,
    Member's Choice, May 2015
On the user's DN, configure the 'busy trigger' to be 1. This will return busy tone to callers, and disable the 'call waiting' behavior that you have now.
Aaron
Please rate helpful posts..
Jamil Hussain Wed, 04/14/2010 - 05:36
Aaron.
Yes this is also the way to do
but is it possible that the bell rings on it and the calling party can see his status on Cisco phone that he is busy.
Can I do it like this way
Best regards,
Jamil Hussain
Aaron Harrison Wed, 04/14/2010 - 05:39
Once you have dialed the number, you can only get ringing or busy tone. You can't be notified that you are 'waiting'...
However, you could enable the Enterprise Parameter 'BLF for Call Lists'. This would display an icon (on phones that support it) that show whether the caller is on the phone in the directories, missed calls, placed calls etc.
For this to work you would have to do a few things:
1) Enable the enterprise parameter
2) Ensure that all phones/users have a SUBSCRIBE CSS set to include all internal destinations
Aaron
Please rate helpful posts...
Jamil Hussain Wed, 04/14/2010 - 05:47
Hi again aaron
The below solution which you provided me how the calling party know that called party is busy.
On his phone its showing blf
How it will work.you mentioned in the directories missed calls ???
Best regards,
Jamil Hussain
Aaron Harrison Wed, 04/14/2010 - 05:52
Yes, when you search the directory, each entry will show whether the phone is on hook or not.
Same in placed calls - so you can call someone, and if they don't answer you can look at your placed calls and see whether or not they are on the phone.
Aaron
Jamil Hussain Wed, 04/14/2010 - 05:48
Hi,,,
How I can use that script ????
Best regards,
Jamil Hussain
Jamil Hussain Wed, 04/14/2010 - 05:57
How I can get that script to be used ?????
Best regards,
Jamil Hussain
